Re: 1961 Red Fish Flooring Repair
Red Fish built some cool boats- Which model do you have??
The 1961 brochures, along with lots of other info, can be found here-
http://www.fiberglassics.com/library/Red_Fish
If the floor is rotten, you can bet that there is probably rot elsewhere. You're going to have to remove the floor anyways, so you'll be able to inspect better then. Figure that there is a good chance that the stringers, and possibly transom, will also have some issues. Now- Here is the 'bad' part- I don't want to alarm you TOO much, but Red Fish used balsa core construction in the hull- and, as such, there is a pretty good chance that the hull coring will have issues, too, if water got in there, which is highly probable. It IS repairable- Just takes some effort.
Now that you've heard the worst case, dig in and inspect- And hope for the best
-Andrew
