Re: 1961 johnson 40 hp engine
Yes.
Battery (+) to starter solenoid.
Other side of starter solenoid to starter lug.
Battery (-) to engine block.
A fused (+) positive wire to the ignition switch battery connection.
A wire back from the ignition switch start connection to the starter solenoid coil connection. The other side of the solenoid coil needs to be grounded if using a marine solenoid (recommended).
The two black wires from under the magneto plate go to the M terminals on the ignition switch to kill the motor.
