1961 johnson 18 hp. Should that be there?
ryan 98
So I've had an 18 for years but she just got too tired and busted up. Picked up what appears to be a super low hour matching motor to my old one. I've been going through it thoroughly to clean it up and make it reliable. My question is I found what looked to be 2 o rings in the end if the crank where the driveshft splines in to. Looks exactly like the o ring that goes in the Grove on the driveshaft. But there's no way an old one could have slipped off and made its way in to there during a past water pump change. Especially not 2. So are these prone to a driveshaft rattle? Splines are dead tight in there. Old mechanics trick to keep it quiet? But I can't see how you would get them in there without pulling the powered and it looked to have never been off. I can't see 2 o rings stuffed up above the driveshaft being factory omc. but I also can't see how someone got them in there, or why they would have. Any thing you guys know that I don't? Almost seems like a smart idea to keep the driveshaft pre loaded in to the lower end a bit. scan0432.jpg
F_R
Honorary Supreme Mariner
Should be only one o-ring (in the groove around the drive shaft). Matter of fact, if there was anything pressing down on the drive shaft, it would make the gears whine.
ryan 98
I wonder if your on to something there. Maybe the lower end is worn out and they were trying to add some preload. It's just a set of 90 degree bevel gears in there right? Anyway all put it back together without them and see. At least I have a known good lower end on my other motor.
