Re: 1961 75hp carb float
I did some poking around and could not find one. I know of two options. First you could go to a dealer and have them check for you. They have access to vintage parts and can get them for you, however it may end up being another cork float. The other option, if yours is in good condition is to recoat it. I have just picked up some fuel proof dope that is used on model airplanes to recoat mine (a 52 Johnson). I had tired epoxy and was impatient putting it back in before it was completely cured. It flaked off and clogged up the carb. So now I need to sand it down and coat it correctly. The last option if yours is shot is to get some balsa wood carve a new one and coat it up. Someone else may post up with a source, but at least you now have a few other options.
