1960s Johnson 40 electomatic
Beforemytime
Hi everyone
I have a 1960s Johnson 40 electromatic. I have been restoring a 1956 wooden runabout with this motor and just got it out on the lake last week. It starts and runs great but the gearing is reversed meaning when I shift forward it is reverse and reverse Is forward
inside the control box some so splicing has been done on the shifter switch and there is new green and blue leads coming from the gear case in the lower.
It is a counter clockwise flywheel rotation and the shaft has a left hand prop.
Is the forward and reverse gearing the same in this engine? Meaning if I am constantly running on the reverse gear for forward will it wear or break quicker? just thinking if the linkage is connected wrong in the lower I will have no way to tell which gear is activated without dropping the lower right? Would I be able to tell by prop rotation?
Thanks in advance.
Honorary Supreme Mariner
NO, no-----Switch the 2 wires at the motor.-------Lower unit is not designed to run full throttle in reverse.-----There are no shift linkages in the lower unit either.------Something is totally wrong here as the motor should not be running backwards !!----Stop and investigate before you ruin this motor.
jimmbo
The shift mechanism would not work if the engine was running backward(counter clockwise when viewed from above). How to start that engine backwards would be a challenge. Water pump would not work either. All props for those engines are right hand(clockwise when viewed from behind). In forward, the prop spins clockwise, reverse counter clockwise when viewed from behind
http://www.fiberglassics.com/library/images/a/a7/Evinrudeservice002.pdf page 57
Green wire is reverse, Blue wire is forward
There are no linkages in the lower unit, no clutch dogs to move. Shifting is done by electromagnets, which cause a spring attached to the gears to grip a hub splined to the propshaft
You can determine which coil is energized by rotating the prop shaft. When the forward coil is energized, the prop shaft can be rotated clockwise with little resistance. Rotating it counter clockwise, resistance will be felt and then the shaft will stop. With the reverse coil energized, the prop shaft can be rotated counter clockwise with little resistance. Rotating it clockwise will provide resistance and eventual stop. Remove the spark plugs or disconnect the leads and ground them. It is possible for the engine to start when rotated by the prop shaft. Actually that would be about the only way to easily start the engine backwards
F_R
What jimmbo said is accurate---except green wire is forward, blue reverse.
If everything is working but shift is backward, the wires are swapped.
jimmbo
I quoted what was in the manual the link I posted. I checked a later version of that same manual, and it says what you said. Damn typos
