Beforemytime
Thread starter- Joined
- Jun 24, 2018
- 1
Hi everyone
I have a 1960s Johnson 40 electromatic. I have been restoring a 1956 wooden runabout with this motor and just got it out on the lake last week. It starts and runs great but the gearing is reversed meaning when I shift forward it is reverse and reverse Is forward
inside the control box some so splicing has been done on the shifter switch and there is new green and blue leads coming from the gear case in the lower.
It is a counter clockwise flywheel rotation and the shaft has a left hand prop.
Is the forward and reverse gearing the same in this engine? Meaning if I am constantly running on the reverse gear for forward will it wear or break quicker? just thinking if the linkage is connected wrong in the lower I will have no way to tell which gear is activated without dropping the lower right? Would I be able to tell by prop rotation?
Thanks in advance.
Thanks in advance.
