Ok so just bought a boat out of the blue because my girlfriends friend needed money (never owned a boat or new much about boats). Did some research and found out it is a 1967-69 glastron with a 1965 40 hp johnson motor with electric start. Previous owner said it ran so i assumed it did. Got it home and started tinkering with it. Had to install a new starter solenoid and re wire all it all back together. Got it to crank over and pretty much start right up within a couple seconds.(had it in a garbage can filled with water) But the problems i am having is that the lower cylinder is not getting spark, switch plugs to check that and that was not the problem. Not sure if the if it gets spark from a one or two coils or where they are (havent dug that far into the motor.) If someone could help me out here and give me some ideas to check it would be greatly appriciated. I would like to post pics here soon if you guys would like them. might help us both out.
thanks kevin
thanks kevin
