1960 Larson All-American steering
tdurb1327
I need to upgrade the steering on my old boat for a bigger outboard (1973 65 hp Johnson). It currently has a dual pulley system and the bigger motor stretched the cables and broke off one of the pulleys. i am assuming it needs upgraded. After some research, what teleflex steering system should i use to keep the factory steering wheel? Rotary? and would this be fairly easy to install? Thanks for any input.
Daviet
Re: 1960 Larson All-American steering
You could use either system you mentioned, you will have to check with the manufacturer about the steering wheel fitting. Normally not to hard to install, depending on the room under your console.
tdurb1327
Does anybody know about the steering wheel or had experience with this same boat? Thanks for all replies!
