Still working my gearcase in my other post, and figured it can't hurt to ask about this issue. Its the RDS-22 model.
Motor runs great, good and strong, but the low end speed seems way off position. This motor has the external dial where a tiller would attach, and has 2 (or 3) marks on it, SLOW START (and maybe fast? did not notice). When at idle the dial is sitting at start, or just a smidgen below. That in itself is not an issue, but the mercury switches inside at the end of the dial rod do care, a lot. Top speed in idle is probably 1500-2000 rpm (shift interlock), but it won't start above maybe 600 - 800 rpm due to the starter interlock switch (electric start). Makes starting cold tough as you have to increase the throttle the instant it kicks, which cuts out the starter.
I found a screw clamp on the end of that dial rod at the switches, but even if totally loose I can't turn the dial to get more starting range. It acts like it may be keyed, but it's quite a bit of linkage removal to know for sure. Does anyone know if this is a slip fit, or keyed?
On a similar note, the magneto range seems to go way below where this motor idles, like 10 degrees or so, just like the unusable dial movement from start to slow. I had to remove the original nylon idle adjust screw and put in a longer one to keep the throttle from going low enough to stall. It idles fine, runs for 30 min at idle no problem. We synchronized the carb with the mark on the magneto plate as per the instructions, so that should not be an issue. Is it typical for the magneto to move way beyond the actual running range? If not, any idea why this one might? I don't see any adjustment points in any of the linkage, other than the rod to the carb throttle plate that sends it WOT once the magneto stops turning, and the magneto/carb sync adjustment noted above. The difference between my idle and the idle mark on the dial is probably 60 degrees, and WOT is about 90 degrees above start. Sure seems like the actual idle should be closer to idle position than the start position. The Ship Master control also suggests the range is short. It only uses about 1/2 it's range from idle to WOT.
I'm a whole lot more familiar with old inboards, specifically Chris Craft 283's. Rebuilt a pair of them in my 1962 28 footer.
Thanks, John
Thanks, John
