1960 Evinrude 10 hp carb rebuild?
zino
Been working on a 1960 Evinrude 10 hp, replaced coils, points, condensers, spark plug wires and fuel lines. New fuel hose and bulb. Started on 3rd pull, runs rough, seems to be burping, adjustiing low and high speed needles does not seem to make a difference. stalls out on low idle and can only restart with choke out. Thought I could get by without carb rebuild. Does this sound like a carb rebuild?
badbaja
Re: 1960 Evinrude 10 hp carb rebuild?
Yep It is a very easy carb to clean too.
jimdd810
I agree if you adjusted both of the needles and no change then definatley time to rebuild the carb.
