Need some expert direction please. I recently purchased a 5.5hp evinrude which has sat for some time. Compression is good but does not run. I began by rebuilding carb and replacing fuel lines and plugs. Had engine running for about 30 seconds and have not been able to restart since then. I also noticed excess gas sitting in carb opening in front of butterfly valve. I then removed carb and checked float valve and all gaskets and seals which looked ok. Still unable to start
Suggestions please? I have new ignition parts to install but since the motor ran I suspect there is a problem with fuel system
Thank you
Doug
Thank you
Doug
