1960 40hp johnson ignition problems
peewizzzle
my motor wont start from the ignition, i turn the key i hear a click thats it. my batterys charged, what can the problem be.
tx1961whaler
Re: 1960 40hp johnson ignition problems
Probably a dirty or loose connection. Take loose and clean every connection from the battery to the starter, including the ground connection to the block.
JB
It is most likely a very common, easy to prevent or fix, problem: corrosion in the battery cables or their connections.
Take loose both ends of both battery cables. Check the cables for swollen or weak spots. If you find any, replace the cables. If not, carefully clean all connections and reinstall.
Let us know the result, and good luck. :)
F_R
Honorary Supreme Mariner
The wing screw that holds the cable to the side of the motor is the ground connection. It must be there and clean and tight or you have no negative battery cable connection.
peewizzzle
i cleaned all the terminals all wire connectors and nothing i checked the positive and negative wires for power going from the battery to the motor theres power, but then i checked the power at the motor theres is nothing, so im guessing it might me something in between?
royal0014
Master Chief Petty Officer
Look at the wiring diagram and check for voltage at the solenoid. One leg is straight from the battery. Another runs to the starter. A smaller wire runs from the ignition switch.
peewizzzle
bad starter solenoid just jumped it with a 6 gauge battery cable thank you everyone
peewizzzle
actually i replaced it and it didnt work same problem terminals are all clean no loose wires now what... could i take two wire from each side of the starter solenoid and attach it to a heavy duty switch
lindy46
If the starter turns when you jump direct to the battery, then the problem is somewhere in between. Did you replace the solenoid with a proper marine one?
peewizzzle
no i used a car solenoid i didnt think it would make a difference as long as it was for a 12volt system and it had the four posts
mike1245
yes it will make a differance also check key switch i just went threw same thing and it winded up being the switch
tx1961whaler
A car solenoid may burn out the neutral safety switch, if there is one.
royal0014
If it turns out to be the key switch, DO NOT use an automotive switch. It will send 12 volts to the coils and destroy them!
peewizzzle
could that be the problem, the ignition switch? could that be the reason theres power going to the outboard
lindy46
Different ground set-up on an automotive solenoid.
peewizzzle
i finaly got it started then shut it off. went to go start it again turned over started it puttered out then wouldnt start again now i have no spark in either of the two cylanders now what??
mike1245
im still saying key switch
peewizzzle
i replaced the coils i had spark lost park got it back lost it again there was then i weak spark but then all of a sudden got good strong spark but now it wont fire its very frustrating
peewizzzle
which wire is the kill wire(s). i finnaly got it started now it wont start again but i do have spark i replaced the key on the flywheel
mike1245
black with yellow strip
