1960 40 HP points/coil plate install
moodycounty
OK, I think I have figured out that on a 1960 rds-22 the condenser wire, the little wire from the coil, and the black kill wire all attach to the screw on the points, does anyone know if this is true? Also does it matter which coil wire gets routed to which plug? Thanks
F_R
Re: 1960 40 HP points/coil plate install
Yes and yes.
Don't have the 3 wires sticking up to where they will rub on the flywheel.
The coil closest to the front (forward) of the motor goes to the top cylinder/plug wire.
moodycounty
Thank you imported F R, just what I needed to know !
