FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Re: 1960 18hp johnson not pumping water in neutral
I am running it in a barrel and the water is high enough.it will pump water but not always in neutral if u put it in gear and then back in neutral it will pump in neutral.had lower unit apart and impeller looked good.
You've received excellent advice. Replace the complete water pump. That will solve your problem UNLESS you have a failing head gasket that would be allowing the combustion power enter the water passageways causing a stalemate which isn't likely.
I agree. Impeller AND housing. It's weak. My '66 18 did the same last year. I replaced the impeller and the water flow was still weak, almost non existant in reverse, then I replaced the housing (which looked fine) with a different used one and it pumped great, even in reverse.
