water fowl
Thread starter- Joined
- May 30, 2012
- 6
I just bought a 15-foot fiberglass 1959 Performer runabout .
You know the story....The wood two layers below the seats led to lots of rot.
The stringers are okay, but the ribs, the main part of the wood in this hull, are rotted in the bilge area. I?m still getting to the transom inspection.
I cut out the floor, except a 6 inch perimeter around the outside.
Here's my plan. Chime in!
1. I will Leave the six-inch perimeter of the original floor.
2. Cut out the rotted wood. Spray the mold with MoldAvenger.
3. Leave the un-rotted original rib sections that are closest too the hull.
4. Replace the interior rib wood with douglas fir coated with epoxy.
5. Tape over the new-old rib connection joints with fiberglass onto the hull
6. Plop a ? inch marine ply over the entire original floor- pre glassed, and glassed down.
7. Somehow fix the transom (no solid plan and I won?t start the project until that?s planned out.)
It appears the original rib wood was douglas fir.
At times I?m temped to shove pressure treated 2x4?s under the floor, but calm down later.
Any Help?
Also: it came with a not yet running 1958 Johnson 35 Javelin outboard for $250 . If that vintage has any collector interest, let me know?
Thanks guys.
-Water Fowl
Any Help?
Thanks guys.
-Water Fowl
