1959 Lake N' Sea Restoration
Woodonglass
Re: 1959 Lake N' Sea Restoration
Andgott, try some Mothers Mag and Aluminum Polish on those old pieces. You'll be amazed!!!
andgott
Master Chief Petty Officer
I've used that before, works pretty well! I have to remove the old anodization, some deep scratches, and polish it- So the compound on the wheel makes relatively quick work of it. I will follow it up with a polish like that- And use it for 'upkeep' as well...
-Andrew
rrumba
Ensign
hey Andgott,
congrats on the addition and new first mate. any little progress is progress. good luck with the new job and travels.
andgott
I got a bit more done... My schedule at this point only allows short amounts of work time- And it looks like it'll stay that way at LEAST until sometime next year! But, I'm still getting the project done bit at a time.
I did the final adjustments here and there to line up the hull and deck, did a test 'dry' fit, then joined the two parts. It is now ONE-
I used every clamp or device that I had that could provide clamping pressure to hold it all together as the adhesive cures. The fit was pretty close, though it appears that the hull sagged a little bit while the two were apart, though with a little persuasion everything fit together nicely.
I was a little nervous about the fit- The way this thing was built, everything has to be PERFECT for it to all go together. I took a lot of measurements, and tried to make sure that I put it all together right, but had no way of really knowing until I tried to reassemble. Luckily- It all fits!
Once it cures, I'll re-install the aluminum rubrail with stainless fasteners. Then, It's time for deck hardware- And the Windshield project!
-Andrew
jbcurt00
The L&S is looking fantastic! Great work.
andgott
I got the rub rail partially installed-
Starting to look like a boat now instead of a project :)
sphelps
Looking good ! Can't wait to see her all dressed up !:cool:
Trooper82
SOme great progress Andgott...looking purtee too!
Cowboyup94
boyfriends [a good time to meet them is when you are sitting at the dining room table, just cleaning that 'ol gun;)]
Make sure you tell the boy, "That's my little girl, before you think about kissing, hugging, or any other possible activity remember I'm not afraid to go back to prison."
andgott
A very productive day here! I actually found some time to work on the boat! Our last term was only two weeks long- They managed to compress a 15 week chemical engineering course into two weeks- Which didn't leave a lot of time for anything else! But, It's over, and I get two whole days before the NEXT semester starts!
I got a lot of hardware installed today, including drain plugs and the aluminum transom plate-
I also cut out a hole in the deck, under the transom, for a 3" access plate so I can get into the bilge should I ever need to.
I also got most of the new hardware (frames, etc) made for the windshield. I bent some aluminum moldings, and polished everything up. For some reason, I'm having difficulty finding the 1/8" lexan that I need locally.
This boat MIGHT actually see the water before I head off to Germany in January!
-Andrew
jbcurt00
Looking great! DIY windshield molding, nice. Hope the fab work details make an appearance when you get time.
GT1000000
That is just one very cool looking boat, and it gets better looking with every new addition...way to go!:D
TruckDrivingFool
Looking great, all that work fitting looks to have paid off.
Is that a bilge and a deck drain?
rrumba
Ensign
andgot,
nice work in between your busy schedule. the paint looks great with the fittings.
andgott
Thanks- She's coming along. Slowly, but surely! It's not a race, after all :)
Yep. There's a drain to the bilge, which is the lower one, and there is a drain at deck level, the upper one. Originally, that lower drain was the ONLY opening to the bilge area- Now there's a 3" deck plate in the floor under the motor well so I can get down there if I need to. The splashwell drain is not drilled through yet, that comes next.
southkogs
Lookin' great Andrew - Definite improvement on the bilge over the original design.
andgott
The Three day weekend has given me a little time to get some boat work done.
The wheel needed some attention, it used to have some funky blue sparkle vinyl coating on it, which had mostly cracked off-
So, I stripped the rest of it off. My original intent was to repaint it, but it polished up VERY nicely, so I decided to leave it that way-
And, I got the rear seats installed, plus some of the deck hardware-
The stern seats are hinged on the bottom, and pivot forward to allow access to the area under the motorwell. The seats come out easily, by removing the pins. For that reason, the seats are often missing when you find these boats!
You can see the template for the new windshield in the last shot, I finally found a local source for the lexan, and will be picking it up next week. I hope to find time to get it cut and shaped next week.
I'm still collecting a few more parts, mostly for the dash, and then it'll be time to put the motor on. Then its LAKE TIME!
-Andrew
