1958 Western Auto 5 1/2 hp Wizard Powermatic mfd by Oliver
M
mrcrabs
Guest
Re: 1958 Western Auto 5 1/2 hp Wizard Powermatic mfd by Oliver
it sure is white...I like white :)
coolbri70
i like white too, but this is so bright dont know if i can look at it in direct sunlight without eye protection:cool: might do a few coats of off-white the part of the lid past the 1st ridge was originally green, i was going to leave it white till i get a jon boat for it then paint that part to match the boat
coolbri70
so the wife was in the garage earlier and she said " thats really not a bad little motor, we should keep it and get a little jon boat to put it on" a few weeks ago it was "i can't believe you paid $75 for that" all i did was clean and paint it. also i cleaned the points to get it sparking and drained water from the lower unit, took apart and cleaned it then sealed, filled it. :cool: her change in opinion is based completely on the paint:D
M
mrcrabs
Guest
I'm still hung up on Super Banana Yellow :)
M
mrcrabs
Guest
in 1958, my birth year pastels were the rage, you may have seen my 57 pastel blue Scott Atwater, I may go pastel yellow with the hood on it, I think pastel yellow was a factory color for SA back then.
I had never heard of "Super Banana yellow" until about 1972-3ish there abouts when a high school buddys dad bought a new dodge truck with that factory color, we had many a chuckle over Howards yellow truck...it kind of stuck with me for the rest of my life.:happy:
You have a classic and valuable old outboard there, I sure would stick as close to factory as I could on that one and hang the Jon boat color
coolbri70
i found a old brochure that said they could be had in green red or black, the lids, they were all a cream/white leg and housing
coolbri70
i have a few things i have to get done today for the mrs:facepalm: then later i want to start this motor:D i see a low speed rich/lean and high rich/lean, a choke. no on/off switch. i have spark allways, so how do i shut it off if it starts:confused: does the tiller throttle control cut off the fuel when closed? to start, throttle half way? starting lean/rich settings? any help on the starting procedure appreciated
coolbri70
havn't tried yet but im definitly getting her going tomorrow, i need to mount it to something solid as its a little hard to pull, can really feel the compression, hard to think i was spinning it by hand with the plugs out checking spark:D its so light i have to hold it away while i pull the cord. the tiller handle had markings but i can't tell what they said
coolbri70
got it in a tub of water, been pulling the cord, got a couple pops, got to smell burnt 2 stroke, but no putt putt:grumpy: i had hoped it would go easy, but looks like i need to investigate the carb, it was put together with rtv and is dripping from everywhere:blue: bet i find the problem there. also pulled so much the handle broke from the cable, i found a neused one on a broke down mower under the porch that is now fixed:)
coolbri70
i removed the carbView attachment 181506View attachment 181507there was a stink bug in there:facepalm: and other grit and garbage, i will take it to work with me tomorrow so i can clean it and fix it, i will cut a paper gasket and do away with the globs of rtv:rolleyes: i cleaned grit, paint chips and bugs out of here too View attachment 181508
coolbri70
i'm not finding much info on settings or start up procedure, i search the web now and my own thread is one of the first suggestions:facepalm: does that mean i'm the expert :confused: if so, o boy :faint2: this is gonna be difficult to figure out, i mean on some you start out at 3 or 4 turns from seat, and some start at 3/4 turn from seat, it would be nice to know a good place to start. i may just have to rig up some kind of electric starter to turn this till i get it set to where it starts the first couple pulls
Willyclay
One turn "OPEN" from the "CLOSED" position is the initial setting for each needle according to the info I linked you in post#5.
coolbri70
One turn "OPEN" from the "CLOSED" posiition is the initial setting for each needle according to the info I linked you in post#5.
thank you:D the link has changed somehow takes me somewhere else now, i cleaned the carb at work today, the last wrench to touch it used rtv on the gasket and i found pieces of it everywhere:facepalm:the idle screw was crammed full of little rubber pieces. so i'm going to put it back on and give another try
coolbri70
i got it to run:D not well, but it ran for a few minutes, no idle, just reving i was trying to adjust it, so it woud idle and it stalled and i couldn't restart:grumpy: but i got to hear it run, it pumps water and didn't get hot:joyous: got my water dirty View attachment 181639 :D i will monkey with it more after work tomorrow
ronboonville
Sometimes when I'm getting a small motor started for the first time I remove the recoil and use my drill driver and a socket on the flywheel nut so I don't have to yank that rope for what seems like forever.
