Correct, motor will not throttle up beyond high idle in neutral.
That said, under the flywheel, on the port side, there's a horizontal rod that the throttle lever actuates. The rod connects the throttle lever to the throttle arm on the carb. Make sure that's connected and operating. There's a set-screw on the rod that is adjustable to allow full throttle operation.
