1958 lark
Danfishon
engine runs at idle and can throttle up at butterfly but will not go full throttle with throttle lever...any suggestions
oldboat1
has to be in gear to go beyond high idle -- but don't want to do that unless in the lake. Not on muffs.
Chinewalker
Correct, motor will not throttle up beyond high idle in neutral.
That said, under the flywheel, on the port side, there's a horizontal rod that the throttle lever actuates. The rod connects the throttle lever to the throttle arm on the carb. Make sure that's connected and operating. There's a set-screw on the rod that is adjustable to allow full throttle operation.
jimmbo
That horizontal rod that is mentioned, is the fuel saver linkage, there is a specific way it is to be adjusted. I've seen people try to adjust it to set idle speed and others who adjust it for whatever reason. A good service manual will explain it.
