1958 Johnson 35 Super Seahorse Questions
troutchaser-48
I just picked up a 1958 Johnson super seahorse 35 hp. I thought this year motor had dual fuel lines, this seems to have the modern type fuel fitting could this be correct?
I need to replace both lower unit plugs, drain and fill including the small seals. Does any one know if any current parts will fit or do I have to look for old ones?
George
Daviet
Re: 1958 Johnson 35 Super Seahorse Questions
By the parts breakdown I looked at it should have a duel line tank, someone must have converted it to a single line tank.
I beleave current screws and gaskets can be used on your motor.
