I have a model #FDE11 (burgundy, elec start, pressurized fuel tank). It's reliable, always starts and runs. I always forget the oil/gas ratio and have used 50:1 & 35:1 but read recently that I should use 24:1... What do you suggest?
Also, the choke rod connects to a cannister that is about 1.5" diameter and 2" long with a rubber cap that the rod connects through. The bottom of the cannister has a disconnected wire... what is the wire and where should the other end connect?
What is the best way to clean the pressurized tank?
