1957 Johnson - Water Pump Help Needed
adt2
Our first trip onto the water with the recently completed Macomber 15 skiff and the 1957 RDE-19 35HP Johnson was kind of a success and kind of a flop. The boat floated right-side-up and didn't leak a drop of water. The motor started and ran, but not very well and limited our time on the water to about 45 minutes. The main problem was that the motor - which is theoretically oversized for the boat it's powering - wouldn't bring the boat up on plane. It's been years and years since I owned an outboard motor, but it seemed to me that it just wouldn't develop any "torque." It almost sounded like it was ventilating/cavitating at WOT.
We weren't able to adjust the high-speed needle valve properly because the packing was disintegrated, and the nut was too loose (which we didn't know until later). We couldn't adjust the idle-speed adjustment because the motor died at idle.
A quick trip to the repair shop for some first-hand guidance followed by an afternoon of monkeying around with the motor didn't quite solve our problems. Repair dude had a few suggestions:
1) Short-shaft motor hung on an 18" transom; the antiventilation plate is just flush with the bottom of the boat, but there's a 1"-thick outer keel that could be interfering with the flow of water to the prop.
2) Something about pulling the spark plug wires off, one at a time, while running the engine to check if the RPMs fall off. I was looking at something shiny and didn't quite get all of this. I think the gist was, if I pull a wire and the RPMs don't fall off, then the thing is only running on one cylinder.
3) Need to install new packing at high-speed needle valve adjuster. This thing was so loose that it actually vibrated itself out of the nut and fell onto the floor, allowing fuel to pour out while we were under way. We ended up having to hold the valve in place while steering. He gave us the new packing (although he only gave me three "washers," whereas the service manual exploded view shows four) and sent us on our way.
Got home, removed the high-speed adjuster and cleaned out all the bits of old packing in the tube. Flushed everything out and reinstalled the nut and the needle valve. Tightened the nut until the needle valve was snug (i.e. wouldn't vibrate out on its own) and then spent the remainder of the day trying to get the motor started again. Two new spark plugs and a bunch of four letter words later, we got it started - and immediately noticed the water pump was not spitting water out the back of the lower unit.
We cut it off and removed the lower unit. Pulled the water pump and the impeller looks okay, but I picked up a new one today anyway. Also - the O-ring at the top of the shaft was intact if a little grooved, and a second O-ring came off the shaft when I removed the water pump. I have no idea where it came from - it's not shown on the exploded view. It was nearly disintegrated. My guess is, whoever worked on this thing last put the extra O-ring on it. Just to be safe, I picked up a few extras when I got the impeller. Also bought a carb kit in anticipation of future repairs.
All of this is a really long-winded way of asking, what else might cause the missing water stream out the back of the lower unit? I flushed the water tube with a length of garden hose, and either there were no obstructions or I blew whatever obstruction there was out of the way. I'm going to install the new impeller and O-ring tonight and reassemble everything; anything else I should look for? If the new impeller doesn't fix the issue, then what?
Thanks in advance for your help.
kfa4303
Banned
Re: 1957 Johnson - Water Pump Help Needed
Hello again adt2. Glad you got the LU off and can see the impeller. Think you might be right that someone added an extra, unnecessary o-ring into the mix somewhere. There should only be the one at the top of the drive shaft like you mentioned. The impeller itself rests on the impeller plate and is held in place by the impeller key. Sounds like you have good water flow through the power head too. Once your reinstall the impeller properly, make sure you seat the copper water uptake tube properly into the top of the water pump housing. There is a little grommet in there that can sometimes get pinched. The tube itself should already be inserted into the underside of the power head prior to reinstalling the LU. That's really all there is to it, if the passages are clear, the impeller spins and the motor is in a test tank with water filled to about an inch or two below the main exhaust port, it'll pump water. Here's a cross-section to give you and idea of how the cooling system works.
adt2
Thanks. Anything else I need to know before putting it back together? Do I need to oil / grease / lube / fill / empty anything?
kfa4303
Banned
You can drain and refill the gear oil once you've got it all back together (see vid link below), but that's it. The impeller itself doesn't need any lube per se, but a little vaseline on the fins during installation can help them slide into place a bit more easily. You just slide the new impeller down onto the drive shaft, then slide the water pump housing over the top and rotate the driveshaft clockwise only by hand until the housing seats fully. Install housing bolts, then reinstall the entire lower unit. Take special care to see that the water uptake tube seats properly on both the underside of the powerhead and onto the top of the water pump housing. It can be tricky, just be patient and cuss alot if need be:) If you remove the spark plugs you will be able to rotate the flywheel (clockwise only) by hand which will help you get everything aligned. You can also tug up on the lower shift rod thereby putting the LU into FWD gear which will allow you to rotate the prop clockwise by hand which will in turn rotate the driveshaft clockwise. You can get gear lube oils at Walmart or any boat store. Any brand is fine. Just make sure you get 80-90w outboard lower unit gear case oil (see pic, just one of many brands.) You'll also want to get a little pump too (see pic). Good luck. Holler if you get stuck.
http://www.youtube.com/watch?v=a_-ZfbUNT3A&feature=BFa&list=UUqtXoVOxjtEKjjTKj0cFydg
http://www.youtube.com/watch?v=r1misbdj5bI&feature=BFa&list=UUqtXoVOxjtEKjjTKj0cFydg
http://www.youtube.com/watch?v=neYroHtSheQ
http://www.youtube.com/watch?v=z4sSYH16aHQ
adt2
Okay, I need a "plan B."
Got the new impeller installed, plus a new O-ring at the top of the shaft. I also pried off the plate under the water pump and discovered a bunch of disintegrated blue gasket stuff - looks like liquid gasket applied by a previous owner that was past its prime. I couldn't remember anything about applying sealant under the cover plate, and the video linked above doesn't show it, so I scraped it all out and reinstalled everything.
Got the lower unit re-attached in ten minutes or less with no fuss. Beginner's luck, maybe? Put her in the tank, filled up, and fired it up. It started right up (which is a big improvement over her "maiden" voyage on Saturday), but I am still not getting any spit out the back of the motor in either neutral or forward (didn't try reverse). Based on the second post above, if the impeller is in good shape (brand new), the water passages are clear (? think so - I flushed them with the garden hose yesterday, and water went in the "in hole" and came out the "out hole"), and the motor is running (check), then water should be coming out.
I am stumped. What now?
kfa4303
Banned
Hello again adt. I bet the water uptake tube isn't seated properly at one end or the other (usually the angled end that goes into the top of the water pump housing). That may be why it went on so easily. You'll need to drop the LU one more time to check. It's not uncommon to have to do it a few times to get it right. However, once you've done a few impeller changes, you'll be a pro. As you can see from the previous pics, the cooling system itself is very simple and if your got water in/out, the passages are clear all that remains is the impeller, which is new. Start with the water uptake tube seated in the power head, then slide in the LU taking special care to see that the tube seats onto the water pump housing properly. It helps to have an extra pair of hands with a flashlight to help you see, or rotate the flywheel to get everything to align correctly. You were right to get rid of all the goo beneath the impeller plate. There shouldn't be any sealant in, or around the water pump housing. Be patient, give it another shot, and retest it. Keep us posted.
adt2
I'm about 90% sure the tube is seated in the grommet on the pump housing; that was the first thing I checked when I installed it. Is there a chance the water passages below the impeller are blocked? Logically speaking, if the impeller is good, the tube is seated, and the tube above the impeller is clear of obstructions, then the only thing left is the passages below the impeller.
82rude
ive had several older motors with the same water issues.apply a good gasket sealer to the bottom of the impeller housing ,for me, in evey case problem solved.i took one apart at least 5 times till i did this and presto, problem solved.one was a 57 18 johnson by the way.im fond of avaition gasket sealer.looks like molasasus and is applied with a brush.though your not suppose to have sealer on there i find with these old motors it helps a lot.your housing can get slightly warped ,pitted or even a scratch can possibly cause issues.not one motor ive done this way has ever caused any issues afterwards.
adt2
...apply a good gasket sealer to the bottom of the impeller housing...
You mean between the impeller housing and the plate? Or between the plate and the gearcase (which is where I found and removed the blue gasket gunk earlier)? I guess that would maybe explain why I found the gunk down there - maybe a previous owner had the same issue.
Chinewalker
Where is the water level in your test barrel? It should be above the waterpump as they are NOT self-priming. If you ran it on the boat for as long as you say you did, then it must have been pumping.
adt2
The "tank" I use is actually a 45-gallon trash can that is roughly square on top and about 4' tall. The top of the can is at the bottom of the transom bracket, and I fill the thing up to overflowing and just leave the water running (it's a long walk to the hose bib). So the water level is definitely above the water pump.
And it was definitely pumping when we ran it Saturday morning; I'm paranoid about frying motors so I paid attention to it. Here's a re-cap of our day:
  • Launched boat Saturday AM; started fine, ran rough
  • Ran boat about 45 minutes, then trailered
  • Took boat to local repair place for advice on adjusting motor (~1 mile away from ramp)
  • Took boat home to service motor (~20 miles from repair shop)
  • Removed nut and high-speed needle valve
  • Cleaned debris out of port where needle valve was; flushed from outside with carb cleaner, flushed from inside by squeezing fuel line bulb
  • Re-installed nut finger tight
  • Installed new packing on high-speed needle valve, threaded valve into nut finger tight
  • Tightened nut wrench-tight
  • Closed high-speed needle valve to lightly seated, then backed off 3 turns
  • Closed idle adjustment to lightly seated, then backed off 1-1/4 turns
  • Could not start motor (~3 hours of fiddling with it); motor not firing
  • Replaced spark plugs; motor still not firing
  • Fiddled with high- and low-speed adjustments and throttle grip and managed to get motor started
  • Immediately noticed water pump not working; shut motor down
  • Replaced water pump impeller
  • Replaced O-ring at top of shaft
  • Cleaned disintegrated gasket sealer from between plate and gearcase
  • Flushed water tube with garden hose; water flows freely out of exhaust port
  • Re-installed lower unit
  • Motor started right up; water pump still not working
kfa4303
Banned
WRONG, WRONG, WRONG!!!!! You do NOT apply gasket sealant to any portion of the water pump, or its housing!!!!! The only gasket sealant that should be used on the LU is on the oils seals in which case 3M 847 is the recommended product.
Also, 3 turns out is WAY too much for the carb needles. Use this link to help you get it dialed in. Don't just "fiddle" with it. Make small adjustments (1/8-1/4) of a turn at a time and allow 10-15 seconds for it to take. Be sure that the motor is not sucking in exhaust gas while in the test tank either as this will impede performance. A small electric fan can help blow excess smoke away.
http://forums.iboats.com/showthread.php?t=167352
Regarding the water pump. Assuming it was installed correctly and the passages are clear, it will work. Pay special attention the the copper water uptake tube seats properly in the top of the impeller housing. Check that the impeller key is properly installed as well. Without it, the driveshaft will spin, but never engage the impeller. You must also run the motor in a large barrel (55 gallon rather than 5), or trash can. Also, the entire lower unit MUST be completely submerged with the water level about an inch below the main exhaust port.
adt2
WRONG, WRONG, WRONG!!!!! You do NOT apply gasket sealant...
So, what you're saying is, don't apply gasket sealant? :)
My plan of attack for this evening is to remove the lower unit, remove the pump housing and plate, and flush out the water passages under the water pump. Then I'll put it back together, re-install the lower unit, and double-check that the water tube is seated in the grommet on top of the pump housing. After getting it all bolted back together, I'll fire it up and see what happens.
kfa4303
Banned
adt2
No worries; that's just about what I've got (what's shown in the videos plus a couple of inches).
adt2
Okay, we have good news. Took everything back off and flushed the water passages ahead of the water pump with compressed air. Put it all back together and we have a winner! Now have a great stream coming out of the back of the lower unit. Thanks to all who helped diagnose and fix the problem.
And now, the bad news. I have two immediate problems, which may or may not be related.
First, I can't get the motor to idle. It might actually idle if I could adjust it, but the friggin' twist-grip throttle has no resistance at all and just spins back to dead, killing the motor.
Second, and almost certainly related, I still don't think the twist-grip throttle is working properly. The gears at the elbow just barely mesh (it's like the linkage coming from the twist-grip is a quarter-inch too short; the teeth are just barely long enough to mate with the gear on the motor), and with any force at all, they slip, allowing the twist-grip to rotate 360 degrees. I've looked underneath the tiller arm, and I can't see a way to adjust the length of the linkage. I took the throttle handle off, because it's cracked; the spring is inside there, but I have no idea whether it's still got enough "sproing" or not.
Any tips on where to go next?
kfa4303
Banned
Sweeet! Glad it's pumping water! As for the tiller, it may need a couple washers on either side to get the gears to mesh. I would just take the tiller arm off and inspect and rebuild it it using the parts diagram as a guide. There's no telling what a previous owner may have done, or how it may be damaged/modified over the years. In the interim, you can apply throttle to the motor as needed by manually adjusting the base of the throttle tower at the site where the throttle control cable would connect. There should also be an idle set screw in the same location. The original screw was nylon, but they often become damaged, or stuck over the years. If it still works, great. If it's damaged remove it and replace it with an 1/4" x 20 x 2" stainless steel bolt. Twist it in to raise the idle and back it out to lower the idle. Again, only small adjustments are needed. As you back it out, the idle will drop, which will allow you to turn the Lo speed needle on the carb in slightly to raise the rpms again. You can keep repeating this until you get a nice low idle.
http://www.marineengine.com/parts/v...ntage-evinrude-johnson/377023/37702300001.htm
HighTrim
I actually seal the impeller plate to the gearcase, you dont want air entering the housing. 3M 847 is a good product for this. I also use OMC Gasket Sealing Compound on the impeller housing screws. So, I wouldnt say you shouldnt use it anywhere near or on the impeller housing.
Regarding your tiller, take some pics of what you are dealing with.
adt2
Okay, here's where I think the issue is:
The two "gears" just barely mesh. You kinda sorta have to keep pressure on the tiller arm, pushing it back toward the transom, to keep the teeth engaged; otherwise they just slip past each other. My parts manual does not contain an exploded view (or any view, for that matter) of the tiller arm assembly, so I'm basically winging it here.
And I need somebody to refresh my memory (it's been probably 25 years since I operated a tiller-steer outboard): Should the twist-grip "spring back" when released? One of the reasons I'm having a hard time making adjustments is because as soon as I release the twist-grip, it rotates back to "slow" and the motor sputters and dies. (And it rotates back quickly - like it's spring-loaded. There's barely enough time to switch from one hand to the other.) I don't think I remember my little outboards working that way when I was a kid, but then that was 25 years ago so who knows.
Finally, it would be great if one of you could give me an idea of how far the twist-grip ought to rotate. Mine will only go about 90 degrees - from about 12 o'clock to about 3 o'clock. (Until the teeth come out of mesh, at which point it'll rotate all the way around.) This is both in neutral and in gear.
Chinewalker
Couple things to check on the throttle slowing down on its own. Is there ANY chance at all that the flywheel is contacting the coil heels? Even a slight rub will want to spin the stator plate back to the slow position.
Second, is the spring's seat present, up inside the tiller grip? It's a small, round piece with a hole in it and two small nubs on it to align in the end of the tiller casting. It is #121 in the diagram. If that's missing, you won't get proper friction in the grip.
As for the gears, as was noted above, disassemble the tiller handle and add a washer under the gear to space it closer to the motor-side gear. You want the gears close, but not jammed together. A tiny bit of clearance helps them last longer.
