1957 Johnson Outboard Revival...18hp FD-11
TiredOldJohnson
Hello All, I am very new to the boat scene but have been working on dirtbikes/small engines for awhile now. My grandfather had an old wooden boat with a Johnson 18hp motor that has since rotted away. I am left with this motor that had been left laying covered outside for probably 10+ years. I am trying to get it running but am running into a few snags. Since getting the motor I have...
Checked the compression which is in the correct range and has equal readings for both cylinders
Installed new spark plugs
New gas tank. Its a used gas tank from the period but in amazing shape.
New dual line going to the tank
Fresh gas with the recommended 24:1 mixture
Cleaned the other fuel lines and carb
I tried to start the motor last weekend and every now and then I can get it to run for 5-10 seconds before it shuts off. Can anyone let me know what settings I should be starting this on as im sure most of them are in the wrong position.
Also where can I buy parts? I am wanting to replace the other fuel lines. Can someone tell me if I should just buy a generic size fuel line or if they need to be specific?
Any info or tips would be much appreciated.
F_R
So you have so far ignored the ignition system? For one thing the coils have a 100% failure rate, unless they have already been replaced. And of course there are the points & condensers.
Advance Auto Parts sells a 3/16" generic fuel hose in two-foot lengths that works just fine.
Initial high speed needle setting is 3/4 turn open, slow speed is 1-1/2 turns open. Adjust from there, running on a boat, on the lake.
Basic parts such as coils, points, carb kit, impeller, gaskets, etc are available right here at iboats. Other stuff at an Evinrude dealer.
TiredOldJohnson
Is there a procedure written up somewhere about how to check the points/condensers/coils? I will be sure to get my fuel lines replaced. Can I just replace the coils by themselves or is there a certain amount of parts that need replaced at once so that they are all new together to function properly?
