TiredOldJohnson
Thread starter- Joined
- May 11, 2015
- 13
Hello All, I am very new to the boat scene but have been working on dirtbikes/small engines for awhile now. My grandfather had an old wooden boat with a Johnson 18hp motor that has since rotted away. I am left with this motor that had been left laying covered outside for probably 10+ years. I am trying to get it running but am running into a few snags. Since getting the motor I have...
Checked the compression which is in the correct range and has equal readings for both cylinders
Installed new spark plugs
New gas tank. Its a used gas tank from the period but in amazing shape.
New dual line going to the tank
Fresh gas with the recommended 24:1 mixture
Cleaned the other fuel lines and carb
I tried to start the motor last weekend and every now and then I can get it to run for 5-10 seconds before it shuts off. Can anyone let me know what settings I should be starting this on as im sure most of them are in the wrong position.
Also where can I buy parts? I am wanting to replace the other fuel lines. Can someone tell me if I should just buy a generic size fuel line or if they need to be specific?
Any info or tips would be much appreciated.
