1957 Johnson Fuel Pump Conversion
olhippiejim
I am working on a 1957 35hp Johnson I drilled out side cover for the new fuel pump is there anything else I need to do to make this motor run on single hose tank the motor is going on my 1957 aluminum Starcraft speedqueen boat
GA_Boater
olhippiejim Gave you a new thread. The one you started in is old and inactive. You will get more help with a new thread. Thanks.
