1957 FD-11 will start with starting fluid?
merkdawg0084
Hey guys been working on this fd-11. Got it to start yesterday just for a second using starting fluid. Tank is holding pressure, just checked all fuel lines at tank and motor. I already rebuilt carb. Anything I could have missed? Thx
Crosbyman
did you blow test the carb..? did you flush all passages and clean the slow speed drip chamber
0302062 filter clean ??
merkdawg0084
No I don’t guess I did the blow test? How is that done? Slow speed drip chamber? I replaced everything where slow speed needle goes and cleaned out the fitting on bottom of carb..
merkdawg0084
Crosbyman,, just looked there is no filter in the fuel filter at the moment. Does that glass filter have to be fuel of fuel? Does fuel run from the tank to the fitting then to fuel filter, then to carb? Thanks
Crosbyman
as you pump the tank .....the filter bowl will fill up then send the gas over to the carb..you should see fuel in the glass bowl
if the carb float works ok air will pass inlet to outlet air will not pass when the carb is held upside down
did you do some reading in the red book ??
merkdawg0084
Yessir I’m reading the book now. Doesn’t say anything about the blow test. I remember reading something on here years ago. Maybe Joe Reeves said something about it one time. The book did talk about the pressurized tank and checking for fuel. Sry it’s taking awhile to reply. I’m not getting my messages.
merkdawg0084
So just blow into inlet, with carb right side up and then turn carb upside down? Tganks
Crosbyman
the low speed drip chamber is under the dime size plug at the rear of the carb just above the throttle plate.. check utubes…
see FD carb layout & troublesome issues in the red book page 139 most of these carb work the same basic way
merkdawg0084
Ok you’re saying red book? I was looking at the actual Johnson service manual for my model.
merkdawg0084
Yessir Crosbyman I did clean out the drip chamber and replaced the core plug. And my fuel filter is on side of motor not under carb. Thx again. Awesome book.
lindy46
Blow into inlet with carb right-side up, and air should pass. Repeat with carb upside-down and air should not pass. That glass filter bowl will not remain full when the motor is running.
Crosbyman
it is just a picture of a diff carb model used on Fds.... same principle same issues to solve
F_R
Why are you convinced it is a fuel problem? Have you checked the ignition, especially the coils? All fd-11 motors have bad coils unless they have already been replaced!!!
merkdawg0084
Yessir it’s getting fire, I replaced all that coils, condensers and points. Delete this comment. Duplicate
merkdawg0084
Yessir, I’ve changed all the coils, points and condensers. It’s getting fire. It will start with a squirt of starting fluid.
F_R
OK, thanks for saying that. BTW, bad coils will often fire starting fluid but not run on gasoline. That's what makes life interesting.
merkdawg0084
I did the blow test today. When I took carb off I think float was stuck closed. It’s working properly now. Hope that was all.. thx
