1957 35hp Evinrude Lark Help
Are you sure that coil was not hooked up to 12 volts ?---Have never seen a coil do that with normal operation.---When those carburetors run out of fuel the engine usually revs up just before it quits.--Try using the manual pump and see what it does.
Squirrel42
Pumping the fuel bulb keeps the engine running just fine. When i let go it runs for a minute or so and loses fuel and dies. Do i possible have a hose backwards?
or something mixed up?
Brand new fuel lines on engine and to tank and new fuel pump. Runs great just have to keep it primed!
Squirrel42
No Title
Here is a view of my line set up!
Squirrel42
I didn't realize it was upside down, now I wonder if i can even turn it around and still have it fit.
I guess you are confirming my lines are correct and it's just the upside down pump causing the problem.
interalian
No, not confirming the upside down pump is the problem, just that they're mounted the other way on any engine I've seen. Hoses appear OK.
Squirrel42
Really appreciate the reply!! Im going to flip the pump around and see if that's the problem. It's got to be the pump, pretty much ruled everything else out.
I have seen some up side down and people saying they had little issues but maybe this pump does not like it.
Dieing to get it out on the water.
oldboat1
That a new pump? Nothing wrong with a used one, but usually want to rebuild them.
Squirrel42
Brand spanking new pump, that's why I'm so confused it's not pumping the fuel to the carb unless i keep squeezing the fuel bulb. very frustrating!
Crosbyman
did not want to read 100 threads... lets start over
1- did you do a air blow test air should flow from the IN to the OUT port of the pump none from OUT to IN
2- the pump works on a vacum pulse from the crank case so the back side of the pump must be sealed with its gasket
3- remove the pump... see if you feel a vacum pulse from the pulse port hole on the side of the engine... the pump needs it !! put your finger on the port and have somebody pull crank the engine or use the starter if you have one . you should feel the vacum pulses
4- with the pump primed with the bulb disconnect the fuel line at the carb and feed the hose in a tomato can crank the engine with the starter and see if gas flows out ... if it doesn't the pump is defective (brand new or not)
sorry if I am repeating previous suggestions....start a new thread.... "defective pump" now that you have it narrowed down
btw... you did drill out a vacum pulse port into the bypass cover... to line up with the back center of the fuel pump pulse port didn't you ?
Squirrel42
1. Did blow test, working on that end.
2. It's sealed with a gasket and yes i drilled the hole! I did notice the gasket blocking some of the hole. maybe not enough air?
3. I'll need someone to help with that, but got no one at this time.
Ugh.. It's so frustrating getting to this point to have the pump not work.
I'll keep trying, thanks for the info Crosbyman!
Crosbyman
make 100% certain the pulses are not hampered by the pump's rear gasket...
if you have good crankcase pulses, pulses can reach the diaphragm . a functioning pump, clear lines for fuel...no reason not to work
keep an open mind... maybe that pump is no good ...check it's operation as suggested in step 4 when you get yourself a buddy
Squirrel42
I made sure the gasket was not blocking the hole at all, and reinstalled it. Still squeezing! Unfortunately I am still working on the electric start. My arm is killing me from pulling this beat for 2days.
I'll try your step 4 when a friend drops by today. Thanks a million Crosbyman!
