1956 Scott Atwater questions....
ScoobaSteve
I just grabbed a 1956 Scott Atwater 7.5hp bail o matic. Clean as can be. Was told it hasnt ran in 2 years and had no spark. Cleaned points, I now have healthy spark. Couple questions...Im lookin for a water pump and assorted gaskets. Anyone have a definite part number. Im finding a couple different options. Also,lower unit oil. It says "grease" and vent. Do I need to remove the gear box and pack with motor builders grease, or will a good 90w gear lube be ok? Should have it running this weekend hopefully. Have a wonderful night folks.
flyingscott
80w90 is.fine.for.the lower unit. New pumps.are available on ebay but be warned I tried one and it did not work well. Honda 4 strke pumps work but have to be shimmed i will be trying my first one this year. Otherwise go to the AOMCI guys on there can make them for.you.
ScoobaSteve
Okey dokey. Ill look for it. Gonna head out to the parts store for some stuff and see if I can get this thing to fire. Thanks for you input!
ScoobaSteve
I know how folks like pictures and I couldnt upload from my phone, so here are a few from earlier. I pulled the "grease" plug and I got a grey goopy liquid. Im guessing I have a slight issue down there. Guess Ill spend this weekend taking the lower end apart and cleaning that out. Till this weekend folks.....
catman977
ScoobaSteve I used to run the old scott engines back in the 50.s. When it was time to change the lower unit gear oil , I added STP back then with the grease about 50-50. Never had a problem with losing any because of the sticky properties of the mix. Today Lucas would do the same.
