FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have a 1956 7.5 H.P. Johnson engine.
Is it necessary to pull the power head (to disconnect the shift rod) to gain access to the water pump?
I've had conflicting info on this problem.
The good news is that it is not as hard as you may think. You will need to replace the base gasket upon reinstallation. Let us know if you need help with this.
