I like to check for spark before test running it -- can do that using a spark tester (plugs out, spin the flywheel clockwise by hand). Spinning it "smartly," should get a strong spark maybe 1/4 or 3/8 inch -- or use the pull starter. Then like to check the carb needles for their initial positions (about 1 turn out from seated for the l.s. needle, maybe a little more, and about 3/4 turn for the h.s.) When firing it up, I like to do it with the cover off so I can check head temperature. You should get a good spray of water from the port on the back of the leg right away. Sink the leg about half way up -- has to be good and deep. Check for water flow, then let it warm up a little and adjust the needles (If she fires and runs, adjust for leaner setting first -- clockwise. Rpms should increase as you lean it out. Back out about 1/4 turn if you get lean sneezing. The throttle idle stop screw is the plastic screw at the bottom of the throttle tower -- can set it to hold a slow idle speed, or back it out to the point the engine will stall when you throttle it way down (another way of stopping it). I like the choke method like Lindy suggests.
[ed. If you Really have it tuned in, it might not shut down even when the throttle stop is fully backed out! Just putts along nice and slow.... Should add the adjustments should be made with engine warmed up and in gear.]
Fun stuff.
