I recently purchased a 1956 Fastwin 15hp which was missing the front cowl latch. I purchased a replacement online and put it on, but I must not have installed it correctly, it won't pull tight when latched. Does anyone have any ideas?
Apparently this is not an uncommon problem. If I recall, I removed the latch assembly and elongated the mountig hole with a rat tail file to allow room for adjustment.
Over years of operation, that spring hook in the assembly will loose it's tension. all You have to do, is take a long nose plier and bend it back to more of a curve and it'll pull tighter when you close it up.
