FV Seek Hunt
Thread starter- Joined
- Jun 30, 2012
- 26
Hi all this my first post. I have some questions about my 56 rude sportwin 10 i have been working on. First thing is i got the motor for free. The guy i got it from said it was seized but turns out it wasnt (awesome for me) it pulled hard at first but then got easier. Then no spark so i looked on here and figured out what to check and guess what coils condensers and points were all sorts of shot. I replaced them all and lets say spark like a lightning bolt. So i put a little fuel in the cylinders 2 pulls and pop it fired for a second (happy times). The motor didnt come with a presure tank so i found one on ebay the tank came and was in great shape. I got some fuel and made my mix hooked the tank up put the motor in a barrel of water primed it and 2 pulls it fired right up and i had it running for about 15 min (more happy times) till this.... I noticed oil forming in the barrel so i shut her down to check if all was ok i tilted the motor up and say that there was white foamy oil leaking from a pin hole above the rear of the lower unit in the back just slightly higher then the gear oil fill hole (and i did change the LU oil) it smelled like gear oil but not sure if this is normal or there is supposed to be a gasket in the fill and drain plugs as in i didnt see any when i took then off to replace the oil could that be my problem or is there somethng else i should be worried about. I just dont want to dump a ton of money into a free motor im already into it for 100. I had another issue with the coils i think moved inside the flywheel because after i shut her down i turned it by hand to make sure was cool and heard a slight grinding inside so i cant run her again till i get another puller to pop the flywheel so i kinda want to address the oil issue before i run all over trying to get another puller. Also even for about 10 min after it was out of the water it was leaking out if this small hole im not sure if it was a weep hole or an overflow of some sort the hole looks to be there for a reason it looks to clean of a hole to be from damage or a drill lol. sorry i have rambled on here but i like to be as clear as i can with things. I hope someone has some insight on this and a cant wait to hear back. Thanks in advance and i am happy to be a new member here
