Hi guys
I inherited a 1956 15 hp Evinrude 15016 and it has been converted to a fuel pump system in the past. There is fuel line going to the pump which is mounted just behind the upper cylinder. Then there is a fuel line from the pump to the fuel bowl on the carb. What I can't figure out is what the short hose is coming from the back of the motor. Could this be what is left of the return hose for the original pressurized system? If so, should this line be plugged since the system has been converted?
Thanks.
Thanks.
