1956 12hp Sea King Lower Unit
Idaho Joe
How do I change the fluid?? I see one screw on the lower part of the unit that says add a certain type of oil but I can not see anything on the upper part of the unit to undo and break the vacuum? There is a small oval panel with 2 screws on the upper part. Is this it or is that where I add some type of grease to lube the shaft??
F_R
Re: 1956 12hp Sea King Lower Unit
The one that you are looking at is the upper, vent plug. The drain plug is down lower, near the top of the skeg. It is just like the vent plug. Do NOT remove the phillips head screw.
