Stickler
Thread starter- Joined
- Feb 5, 2012
- 117
Hey everyone, so today i decided to change the water pump, i removed the power head, disconnected the shift linkage and dropped the lower leg,all went pretty smooth,then i removed the waterpump housing and realized i didnt remove the pin at the top of the crank shaft, i tried using a small punch to tap it out lightly, but for some reason it wont budge, and i dont want to get to rough with it in case i break it off or damage the drive shaft. Im sure someone else has likely run into this, and any advice would be appreciated
Thanks...
Thanks...
