1954 cd11 johnson wont run
Kennym2022
I have went and checked points, aswell as seeing coils were replaced, i have strong spark, but i noticed, it will bark on starting fluid, but not stay running. It has 90 psi on both cylinders, and i can see the bowl of the carb is full. I cleaned the carb, but did not rebuild, and i notice, when the motor starts, the level in the fuel bowl doesnt change
Kennym2022
I also changed the fuel lines and ensured fuel was moving from the tank. Noted, the tank does leak around the gasket, but the primer feels firm
Does spark jump a gap of 1/4" or more?----Pressure tank ?----New fuel filter ?
Is there a glass bowl under the carburetor?----Is there a filter in there ?----Are the 2 hoses hooked up correctly.-----------I can not see or touch your motor.-----But I know those motors inside / out.
Kennym2022
There is a glass bowl underneath which i can see fill up with gas when priming. Both fuel hoses were replaced and i believe were hooked uo correct
The left side of yhe fitting to the carb, right side to the block
Kennym2022
There is no filter in the glass bowl
There was when it left the factory !----What does a compression test show?----Post the numbers here.
Kennym2022
Compression was 90, give or take 2 each way. Between the two cylinders. I just got the motor and im picking uo the last idiots pieces
You have spark.-----You have compression.----So need to look into CRANKCASE compression.----Need to revisit carburetor work.-----I have a couple of these green motors for parts.-----Would be an easy fix here !
Kennym2022
What do you mean by crankcase compression
Filer bowl level DOES NOT change when motor starts.-----Remove the lower carburetor needle.-----Operate primer on the pressure tank.-----Does fuel flow out of the carburetor bowl , yes or no ?
When piston comes down it compresses the new fuel charge in the crankcase.-----When piston is fully down the fresh charge rushes into the cylinder ----It is compressed when piston goes up in the cylinder.-----Many videos on U-TUBE explain this concept,--Some better than others.----See post #17 as I added a test.
Kennym2022
Yes fuel flows out
lindy46
By "cleaned carb" did you take it apart? You need to get a carb kit, and properly clean/rebuild it. Remove the plug on top of the carb and clean the idle circuit underneath the little plug. Clean out all the passageways with spray carb cleaner. I'd also replace the float.
