1953 Wagemaker Wolverine
Chris in Utah
Another question for you Sam... When you attached the aluminum keel/stem metal strip, what hardware did you use? I was thinking aluminum screws to avoid dissimilar metal corrosion, but didn’t you use bolts all the way through?
sphelps
No though bolt . I just used stainless screws set in a bead of 5200 ..
Chris in Utah
Makes sense... I was hoping to use the wood screw option. I should probably find a more sticky adhesive than the LifeCalk I used on the transom. Thanks!
Chris in Utah
Forming the aluminum keel/stem guard ended up being a lot more work than I expected. I have some thin aluminum bar stock on hand, that, cut in half lengthwise, was about the right width for the job. Cutting, grinding, and sanding the two resulting strips ended up being a lot of work however. My back and hands convinced me a brushed aluminum finish was fine vs the mirror finish Sam managed on his.
I drilled/countersunk holes for screws and trial fitted it to the boat.
Then hunted up some adhesive... 3/4's of tube a tube of Loctite Marine Adhesive I had picked up at Home Depot late last year looked like it would do the job nicely.
This was a mistake. Not because it's a bad product, but because it is white and the boat bottom is red, soft, ablative paint. It was very difficult to clean up after the strips were screwed down on top of it. After a couple nights of clean/touch up it turned out ok though.
Then it was time to flip the boat back upright and get it on the trailer. Again, the engine hoist on the front, twin block and tackle at the back made quick work of it, although I'll say (and I guess it only makes sense) it wants to roll upright easier than turtle.
My son and I cleaned the interior with Simple Green and water. That's all I'm doing in there for now. Refinish interior next winter.
Then I took care of a couple more repairs to deck planks and gave the existing exterior varnish a good scuff with 220 sandpaper on the random orbital sander. I plan to put two or three maintenance coats of varnish on it for the season.
sphelps
Looks great ! I used 5200 when I installed mine .. It’s best to tape those areas off to help minimize the mess ..
‘You just have to pull the tape while the caulk is still wet so the edges will lay back down ..
‘Even doing that it can be a real mess . LOL!
Chris in Utah
Thanks Sam. Masking would have saved me some headaches. I guess I thought I could clean it up as I went... just ended up being way more tenacious than regular silicone.
Chris in Utah
I have completed three coats of varnish (sanding with 220 between each) but the forum won't let me upload a photo. :facepalm:
archbuilder
Looking forward to your pics. Apparently there is an issue with uploading pics right now.
sphelps
Very nice ! I like the red hull bottom . Goes good with the mahogany !
Chris in Utah
We got to do a little shake down cruise yesterday. Looks like I won't need those bilge pumps... perfectly dry boat! After some water pump work (lower unit issue, not the rebuilt powerhead) the 1958 Mercury Mk55 (55A engine) worked great too. More details soon, but I wanted to share a couple photos and a video link.
video link:
https://youtu.be/1jsQW8bBJL0
sphelps
No not yet .. I don’t have a battery installed so it wouldn’t do much good . Glad to here no leaks !
Chris in Utah
Like Sam's, my boat was missing the mid bench back rest. I did something a little different from stock, steam bending the top plank to match the deck profile when the seat back is up. It's also built out of a little thicker white oak (3/4" vs 5/8" - I don't have a jointer/planer.) One coat of varnish on (50% thinned) several more to go.
