JoeFromAkron
Thread starter- Joined
- Jul 30, 2012
- 144
No Title
I was able to get back to the shift coupler tonight and victory is mine! I bent it out with away from the shift rod with a punch and took a small pry bar to it. It sounds easy but it was quite an operation. It's up inside the leg with no access panel.
When I finally got the LU off I still couldn't get the screws out and I bent the coupler off the upper rod with channel locks. I had to put the thing in a bench vise to back the screws out. I just had to see.... I think someone put some locktite on em and the screws were bent. Maybe I bent them....The threads on the lock nut on the back of the coupler were pink! Im happy now and it looks like there is no reason I can't use a newer style one if I can't find one like this.
