tailintidecharters
Thread starter- Joined
- Oct 30, 2008
- 21
ok so a buddy borrowed my boat and somehow manages to SINK the boat in our SALTWATER pond. the motor was brought up within 5 min. I drained everything out of the motor and coated EVERYTHING is corrision block. Then put new fuel back into it. She will start usually on first pull but wont run long.(maybe 15 to 30 sec.) Then when you try to give it gas to keep it running it will cut off, or if you let it sit and run it cuts off. Any idea on where i should start to keep it running?........also before this happened it runs great out of water but it seems that the pressure of the water boggs it down and wont run at slow speeds in water. Thanks for all of the help!
