1920p23 quicksilver replacement
jmmdawg
Hello, to be brief. I have 2001 Astro 1950 with 4.3l mercy alpha one. Prop now has 1920p23 stamped on it. Prop has some damage and I want to replace with a similar prop. I can't find that prop listed on quick silvers website. Does anyone know what diameter, pitch, or other specs this prop has so I can find a replacement. Thanks in advance.
steelespike
You may be able to have the prop repaired at a prop shop.23 is probably the pitch which is the key number.
23 is on the high side,good for speed but may struggle with a load or water sports.
jmmdawg
Thanks, I looked through the props on iboats. I was looking at the Solas Amity and Quicksilver blackdiamond 23 pitch. I know 23 is on the high side but my drive ratio is 1.81 instead of the 1.64 and my boats is pretty light so the 23 gives me a good cruising speed. If i buy a new prop. I notice that some props say they come with a new nut and spacer or washer? Will I need this? Can I just reuse my nut and washer? What else will i need?
