1900 2006 Regal Ignition
Justin2253
First, If anyone could help I’d appreciate. I definitely have a couple issues going on with our boat. First thing I’m working on is the alarm system. I had a battery isolator for both of my batteries. I removed and installed a 2 way battery switch (because I kept having a dead battery). After installing, I switched the battery on and my alarm immediately sounded with no key in. So I went ahead and started boat and while it was running the alarm went off. So i unwired the ignition wire and turned the key and it beeped normal like it was priming. So I went on and started the engine. It started fine but the engine sounded a like it may be missing. Thoughts?
alldodge
That isolator doesn't even look wired correct
What motor you working on?
