reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
A few years back I cleaned out an old OMC dealer who had closed up back in 1972.
In the many parts were several factory new power heads, all for electric shift motors. Most were 55hp and 60hp three cylinder models. They sat on a shelf for a few years but I finally found a use for the one 60hp power head, a 1970 60hp Evinrude Triumph that came from a freshwater only area which had a bad middle cylinder.
I did the swap, with new everything, and it runs great, however, I decided to check compression after its first run on the water and was surprised to see a reading of 185 psi on all three holes? Thinking my brand new Snap On gauge was acting up I dug out two others and all agree within a pound or two. Next I got out the other five power heads of this type and ran a compression check on those, and got 180 to 195 on all of the 60hp versions and 165 and 175 on the 55 hp models.
The old motor had 155-100-160 top to bottom, the middle cylinder was scored up pretty bad and the piston looked like swiss cheese from detonation.
The old motor had been sitting for years and the last owner told me he rebuilt it using spare parts from other motors and had spent a lifetime in saltwater.
What was normal compression for these motors? 175 psi plus sure seems pretty high to me.
I was also wondering if there's something about these motors that might give a false or too high reading?
The first thing that came to mind after seeing the high compression was that the starter didn't seem to be straining to crank over the motor.
