185 Mercruiser Engine compatabilty with Alhpa One outdrive
scipper77
Re: 185 Mercruiser Engine compatabilty with Alhpa One outdrive
Are you replacing the motor or the outdrive? My setup is that motor with an Alpha 1 gen 1. (that's a pretty rare motor, assuming it's the 3.8 liter 229 CID)
Chris1956
Honorary Supreme Mariner
You might post this on I/O forum. that '94 OD is likely Alpha I Gen II
Is a 1985 185 Mercruiser engine compatible with a 1994 Alpha One Outdrive?
Ayuh,... Welcome Aboard,...
It depends on How ya wanta mix, 'n match 'em...
