180 sport drain plug
coondogger
I just bought a 2007 Larson 180 sport. I have two questions. First, I noticed there's a place to attach a garden hose to flush the engine without having to use muffs. Can this intake be used to run anti-freeze through for winterizing? Also I didn't notice where the transom drain plug is. Does it use a standard 1" plug, and where is it?
fossill
Re: 180 sport drain plug
Merc or Volvo/Penta?
Carefull with the antifreeze for winterizing. The only kind I use is the non toxic automotive type poured into the engine ( into intake manifold with thermostat housing removed and also into risers) full strength after draining all the water out. Might expensive but not as much as a cracked/corroded block.
transom plug at bottom center of transom.
