18' Aluminum Center Console Build
sschefer
Re: 18' Aluminum Center Console Build
You shouldn't have any problem. Foam is good and I would leave it in unless you have plans to utilize the space. It's only for flotation and not structural.
BigB9000
so I tossed this together:
Figure 1 - the blue is my top stowage area, and the red is my walking area/deck.
Figure 2 - sises, 4'x8' that area is 3' forward from the tansom
Figure 3 - my idea for an easy center console.
How big, deep, wide, and tall should I make it? and how far forward should it be? any other ideas, plans, or comments?
A concern of mine is making it fit in my garage. the thought crossed my mind of hinging it.....?
BigB9000
Another thing, in this pic (of me) you can see where the steering wheel is located, I would prefer mine on the sloping side not the flat area. is that not good? and why is that seat so far back?
Mark42
The seat is back so there is room for the captian to stand at the helm. Some seats convert into a padded leaning post (the seat base folds down to a vertical possition). Can't tell from the photo if yours does or not, but usually if there is a large space, its becasue the seat does not convert and the design is leaving you standing room at the helm. My guess is the wheel possition is a compromise between comfort either standing or sitting.
sschefer
Center Console boats are typically work boats. You're the captain when you're in that seat and responsible for everything that's going on around you. The boat in your picture is set up just for that reason. As was mentioned above, the captain is usually standing so he can see everything going on around him. I know you have your heart set on a center console but ff you want to sit and relax in a comfortable captains chair then you might want to think side console instead.
When that bow comes up and you're sitting down, you won't see anything in front of you.
tashasdaddy
when i built mine, i went with the smallest console i could find. the reason, i want to be able to move around the boat, unobstructed. i use a pedistal seat, that is could remove. the seat is great, i have since done the same thing with my center console pontoon boat.
i was able to get Vhf, controls, guages, am/fm radio, all into this little console.
the seat is a combination butt seat/leaning post. it gave me a 3 point stance, spreading my legs comfortably, and resting my butt on the seat. i was able to see every thing coming at me.
running at close to 50 mph, you have to be able to see.
BigB9000
how far forward did you mount it? and did you buy it or make it?
I see how your controls are mounted, I like that. because is a have a 2 month old side mount controller and I don't want to spend the money on a surface mount. Ill probably do that too.
and our engines look the same too!
I pulled the deck today and discovered the old under it:
top alum thing is bent in the center:
Hull hooked? I put a 8' level across it and the ribs (?) are all straight....
whatever....
