17pitch vs 19 pitch
krovar
got two props 17 and 19 tried 19 5200 rpm 47 mph having some slip right at plane put on 17 which i thought was going to get better bite was very shocked when it blew out at plane 6000 rpm 38 mph both props are same prop different pitch, 17 foot ranger johnson 115
trendsetter240
Re: 17pitch vs 19 pitch
If both those props blow out when you start to plane you might have the motor mounted to high on your transom. The cavitation plate should be even with the bottom of the hull or up to an inch higher. Any higher and you will have issues with blow out like you described.
The other problem might be the trim setting on the motor. If you have power trim then trim the motor all the way in (towards the boat) before you take off and start trimming out after the boat is on a plane. Trim the motor out until it just starts to ventilate then back in until it stops.
If you have manual trim then try setting the trim in one notch at a time and test.
Cheers
Robbabob
If I read correctly, neither prop performs as desired. Check motor height and if you have proper pitch starting points.
Good luck!
