17'Bayliner Capri
happynewboater
Hi- Does anyone know how much towing capacity in a vehicle I would need to tow a 17' Bayliner Capri (1987 I think). It has a 90 hp I/O motor and I think the trailer is about a 17' Shoreliner. Thanks!
KurtG
Re: 17'Bayliner Capri
I'd take a wag at 2500 min. if the hull is dry, 3k or more if it is wet. Check the NADA site for hull weights. You have to add for a trailer, gas, gear, and passengers in the tow vehicle. I believe I/O weights are included, but outboard are not.
What's your tow vehicle and how are your intended ramps like?
NYBo
Dry weight should be around 1,800#, including the trailer.
happynewboater
Hi- Thanks for the replies. I actually figured out that my boat engine is a 2.3 L inboard. My current vechicle is a Volkswagon Diesel Jetta wagon TDI, so I don't think I could use it? thanks
strokeoluck
We pull our 18.5' Bayliner with our Honda Pilot V6. I think it can haul up to 3,500 #. I'm no expert, but I'm not sure I would try to pull your set up with a Jetta wagon.
F14CRAZY
Ensign
I'm thinking it might not quite be right but what's the rated capacity of the Jetta?
Bob_VT
No. That car will not do it.
That Bayliner is about 1800 (Dry weight not counting fuel and fluids) .... your trailer is at least 400-500...... you will be pushing 2500 lbs.
You might have the torque (the TDI is a great motor) but you do not have the capacity.
At best your small car with a small wheelbase might pull 1500 but I would not go over 1000 lbs.
You are only asking for problems.
Go get a cheap tow vehicle like a truck and park the Jetta.
mphy98
i agree, get a bigger vehicle to tow. you may be able to go, but try to stop!!! yikes.
NYBo
The '89 Bayliner brochure (only one I have, OP's boat should be similar) lists the dry weight as just under 1,800#, but the heading on the specifications table states that it applies to the boat with the trailer and standard motor. Not sure if that's true, but a truck scale is the only way to know for sure.
