kbait
Thread starter- Joined
- Nov 13, 2007
- 2,487
Johnson 15 from '74. Had a buddy pick up a craigslist 'excellent condition' motor. You can guess the rest! I fixed the tiller gears, and cleaned and gapped the 'new' points, replaced the 'new' impeller, and barrel tested. Runs great and idles nice and slow. Tested on my boat, and it acts exactly like a 9.9. Nothing wrong at all, just 9.9 power (barely planed me out on a wide 14' alumacraft). I've had a '80, '75, and another '74 15hp motors on that boat this year, and they all flew, and planed fast. Not this one. I immediately pulled the carb, expecting a 9.9 carb, but it is indeed a 15hp carb (I have a 9.9 narrow throated carb to compare). Pulled it apart, and it was pretty clean.. nothing clogging the main jet. Compression is good, as is spark (for a non-cd ignition). Reeds sound good (I pulled plugs, and mostly covered the carb port w/fingers and it makes that cool sound when I spin it over w/socket wrench on flywheel nut). I'll put the cleaned carb on tomorrow and test again, but I feel I'll have the same result.. acting like a 9.9. I didn't get compression numbers, but pulling it over slowly feels great, just like the other 15's I've used lately. Points are perfectly clean and at .020. New NGK b7hs (they work nice in non-cd ignitions). Lower not binding at all, new grease. Any thoughts? (I'm kinda aiming this at BK THE king!) but I'll graciously accept any insights.. I'll check this tomorrow before I put it back together, and I'll definitely post back after I test it tomorrow. I REALLY like the low speed performance of this one.. It'll troll wicked slow for walleyes, but I don't know if it'd plane out w/my girl in the boat w/me, and it's nice to jet to the next spot (like the other 3 15's I've used always do). Thanks, and GO TWINS!
