15hp 4 stroke issue
Limige01
hi guys, i have a 1999 15 hp 4 stroke tiller motor.
it will idle but as soon as you crack the throttle it stalls. carbs been cleaned, fuel pump is good. what do you think i should look at next?
Limige01
theres not really linkage on the throttle. to the carb. just a cam and roller. what do you want me to check for?
my cousin mentioned that sometimes the intake valves stick, he said hes had to replace springs on some small engines like mowers and generators. thats my only other thought right now.
Limige01
valve lash was a little loose, i relashed all valves, lower plug didnt' look like it was burning so i burned it off and placed it into the top cylinder. didnt have time to fire it up today, ill check it out tomorrow. it may have just been a fouled plug.
on this motor you can't get to the lower plug without removing the lower cowling. not a huge deal but probably deterred the last owner from doing it. ill likely replace them with a fresh set soon, it looks as if they are 5 years old or more.
Limige01
i did some more work on it last weekend. motor still wasn't running right, i figured out it is simply dropping a cylinder at idle now. once both are firing i could run on plane no issue saturday.
sunday i put new plugs in and zip tied the spark plug wires back in place and it ran like crap. wouldn't hold rpm while running and would loose a cylinder at idle.
i planned on replacing the coil and wires next. coil number 584451is the oem number.
shows as obsolete. only used ones on ebay, i did find some replacement kit but they wanted $152 for the coil. most coils are 30-40, what gives?
the 2 stroke version of this motor uses a similar coil that is readily availible. anyone know what the difference is? i'm assuming the 2 stroke is hotter, higher voltage possibly. i wonder if i could alter the plug i run and use that coil.
my other thought is using one from lawnmower, since they are 4 stroke as well. i just worry about plugs and heat ranges.
i sent brp an email but i doubt they will help much.
anyone know the best way around this?
152 seems steep, it may not even be the problem.
anyone know the ohms to test the oem coil out?
i'm worried it may be the ignition module
Honorary Supreme Mariner
The coil is different because both cylinders fire at the same time so only one wire from the powerpack.-------Checked for water in the fuel ?.
Limige01
Definitely not the fuel. Did this on different hoses and tanks.
at idle I pulled one plug wire off each cylinder and both times the engine died. So both were firing . Carbs good fuel pressure is good I really suspect module at this point but I'm not sure how to narrow it down. It like an erratic spark.
I also wonder if a valve is sticking but how can I check for that
They had issues with rockers arms wearing or breaking.----Have 3 of these motors for parts / repair.---Does spark jump a gap of 3/8" on both leads ?
Limige01
no, i can jump about a 1/4 but not 3/8. spark is blue
i verified base timing today, the marks line up properly, rechecked valve lash. anyone know the specs for ohming out a 4 stroke coil, number 584451
Limige01
Ok, I bought the gap tester, it will indeed jump a 3/8 gap.
ohmed out the stator that checks good.
ignition coil, primary checks good but when I try to test the secondary it shows infinite, digi won't give me a number.
Limige01
The replacement coil came in today for coil number 0584451.
it was sold under 0584451-kit
the coil they sell you is 583740, they use 2 jumpers to the primary leads tied together with a butt connector to the primary on your engine.
comes with a nice aluminum cnc bracket
Limige01
Took it to a mechanic for a second opinion. He agreed with me, must be the module. I ordered one, once it arrives I'll find out
Limige01
Module seems to have fixed it. Still need to run it on the lake to be fully certain but ran good on the hose after changing it.
