150 throttle postion sensor
jfishstick
Hello, Can anyone tell me where the tp sensor is located on a my2000 150 johnson. I have a check engine light at wot, and am looking to find the code. I attempted to retrieve the code as per the service manual. It says to simulate wot via the tp. I know what a tp looks like, but don't see one on this motor. Maybe i'm overlooking something here?? Thanks in advance.
Dhadley
Re: 150 throttle postion sensor
We'll assume it's not a carb'd motor, right?
jfishstick
hmmm they look like carbs to me. Now i'm confused. If this is a carb'd motor, what would be the need for check engine? I could still see for temp,oil.etc. Help!!
Dhadley
What's in the heads, spark plugs only? Or plugs and injectors?
Faztbullet
This is it....
jfishstick
6 carbs, no injectors. motor does NOT have tps that i can see. Thanks for the pic, service manual shows same. Ideas for check engine at wot??
